Posted September 17, 201412 yr I will spend the next several days catching up this build log. I will be sure to cover the truck's history and how this became my new project. Figured I would start with a pic of it as the first time I had seen it in 2012. I have a few pics I have snatched up of it in it's earlier stages that I will share as well. All I can tell ya...is this poor thing is just a ugly beast.
September 17, 201412 yr LOL, ugly is a fitting description. Looking forward to seeing what goes forth with it!
September 18, 201412 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-06/IMG_50318654815932_zpsfvnqzccc.jpeg.html]The roof ....oh my lord the roof..the external speakers. ...covering so much more wrong under them..all the screws , brad nails, and dents. ..mixed with bondo, bed liner, silicon, resin....you name it....I did not initiate the tear off....I probably would have chosen similarly. ...but I can bet we both agree. ..leaving them alone would of seemed a better choice.lots of work to get it....well...to just a state of okay at best.
September 18, 201412 yr Author The interior. ...wasn't like horrible. ...I mean it was...but seemed do-able....more I looked around. ...less do-able it became....the door panels had to go.URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-06/IMG_50327934565664_zpsjeihavex.jpeg.html]
September 18, 201412 yr You have the good dash for spl. No map pocket under dash.I have the alternator and regulator off that truck.
September 18, 201412 yr So I did miss something how many watts do you plan on running....just wondering
September 18, 201412 yr Author You have the good dash for spl. No map pocket under dash.I have the alternator and regulator off that truck.Steve, this exact truck? That would be too cool if so.I am currently trying to look at some alternator options. Trying to build what I can to keep the budget low for a bit longer.
September 18, 201412 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-08/20140813_172117_zps25zzyxkd.jpg.html]this is a mock up of what I am trying to mess with.
September 18, 201412 yr Author These two singer 275a came from Acousta. Sort of small power and they have the wrong pulleys.So for now..I am just toying with the ideal of doing this route.
September 18, 201412 yr Author So I did miss something how many watts do you plan on running....just wonderingMy original goal was something sort of high...20k+I guess budget and opportunity will be the deciding factors. Time is on my side for now. ..no rush for a while.
September 18, 201412 yr So I did miss something how many watts do you plan on running....just wonderingMy original goal was something sort of high...20k+I guess budget and opportunity will be the deciding factors. Time is on my side for now. ..no rush for a while. you're gonna keep saying that until 4 weeks before slam !!!!! get on it !
September 18, 201412 yr You have the good dash for spl. No map pocket under dash.I have the alternator and regulator off that truck.Steve, this exact truck? That would be too cool if so.I am currently trying to look at some alternator options. Trying to build what I can to keep the budget low for a bit longer.pretty sure. Got from H.V.
September 18, 201412 yr Author You have the good dash for spl. No map pocket under dash.I have the alternator and regulator off that truck.Steve, this exact truck? That would be too cool if so.I am currently trying to look at some alternator options. Trying to build what I can to keep the budget low for a bit longer.pretty sure. Got from H.V.Yup...that would be the same one then!Too cool
September 19, 201412 yr Author This is the roof after cutting all the screws and brad nails flush.....sanded all the resin, bondo, bed liner, & silicon off primed it......since this.....we have used body filler to fill the holes and partially most of the dents.
September 19, 201412 yr Author For some of you...here is the first look into the cabin. .this is the port mouth.Yes....the walls are rough. And yes....the debris is from a brick of fireworks. (Kids will be kids) lol
September 19, 201412 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/2012-05-20_141745.jpg.html]Inside the enclosure of Acousta was very smooth.
September 19, 201412 yr Author URL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-06/IMG_288236720742709_zpseoqp3xae.jpeg.html]Couple older pics....you can see the enclosure.
