Posted October 6, 201411 yr Its been a while since i have kept up with the audio industry and even when i did i was still a rookie. I was lucky enough to have a guy by the name of Alton from this same forum make me box measurements for my car but sadly my car was stolen right before i got to install everything in late 2012. I finally have a car with a big enough trunk to do it all over again hah. So know for my question. I have Two Sundown SA-12 D4's that will be running on a Sundown Saz-1500d v.3 WIth 1/0 gauge xs wire. My question is where and what are your opinions on trusted inline fuse holders that will fit my wire gauge and also how many should i get? Im guessing two. I have seen some pretty pricey holders so i would like to stay under $30-$35.
October 6, 201411 yr Really you only need one close to your battery on the power wire, you could use another towards the amplifier just in case. Here are a few examples from the SSA store: http://store.soundsolutionsaudio.com/products/machined-aluminum-anl-fuse-block.html http://store.soundsolutionsaudio.com/products/shanlsc-anl-fuse-holder-sky-high-car-audio.html http://store.soundsolutionsaudio.com/products/shanla-anl-fuse-holder-sky-high-car-audio.html
October 6, 201411 yr Welcome back! I still have that design too, lol. If you need another just let me know. BTW, I agree with Sean's recommendations.
October 7, 201411 yr Author Really you only need one close to your battery on the power wire, you could use another towards the amplifier just in case. Here are a few examples from the SSA store: http://store.soundsolutionsaudio.com/products/machined-aluminum-anl-fuse-block.html http://store.soundsolutionsaudio.com/products/shanlsc-anl-fuse-holder-sky-high-car-audio.html http://store.soundsolutionsaudio.com/products/shanla-anl-fuse-holder-sky-high-car-audio.htmlThanks a lot.
October 7, 201411 yr Author Welcome back! I still have that design too, lol. If you need another just let me know. BTW, I agree with Sean's recommendations. Sweet! I think my trunk is a little bigger than my last and its not a hatchback. Do you think the same measurements will sound just as good?
October 7, 201411 yr Its been a while since i have kept up with the audio industry and even when i did i was still a rookie. I was lucky enough to have a guy by the name of Alton from this same forum make me box measurements for my car but sadly my car was stolen right before i got to install everything in late 2012. I finally have a car with a big enough trunk to do it all over again hah. So know for my question. I have Two Sundown SA-12 D4's that will be running on a Sundown Saz-1500d v.3 WIth 1/0 gauge xs wire. My question is where and what are your opinions on trusted inline fuse holders that will fit my wire gauge and also how many should i get? Im guessing two. I have seen some pretty pricey holders so i would like to stay under $30-$35. I know how that is, alton did a design for 6 ssa dcon 15s and my truck got wrecked before I had a chance to build it.
October 7, 201411 yr Welcome back! I still have that design too, lol. If you need another just let me know. BTW, I agree with Sean's recommendations. Sweet! I think my trunk is a little bigger than my last and its not a hatchback. Do you think the same measurements will sound just as good? From what I'm seeing it was 37" x 17.5" x 17.5" tuned to 32hz with 56sqin of port area. As long as it would fit it should be fine. Like I said, if you need it redesigned to fit the new car just let me know.
October 8, 201411 yr Author Its been a while since i have kept up with the audio industry and even when i did i was still a rookie. I was lucky enough to have a guy by the name of Alton from this same forum make me box measurements for my car but sadly my car was stolen right before i got to install everything in late 2012. I finally have a car with a big enough trunk to do it all over again hah. So know for my question. I have Two Sundown SA-12 D4's that will be running on a Sundown Saz-1500d v.3 WIth 1/0 gauge xs wire. My question is where and what are your opinions on trusted inline fuse holders that will fit my wire gauge and also how many should i get? Im guessing two. I have seen some pretty pricey holders so i would like to stay under $30-$35. I know how that is, alton did a design for 6 ssa dcon 15s and my truck got wrecked before I had a chance to build it. Damn, Im still upset that i didnt get to install it yet but at the same time im extreamly happy that i didn't because i would no longer have anything.
October 8, 201411 yr Author Welcome back! I still have that design too, lol. If you need another just let me know. BTW, I agree with Sean's recommendations. Sweet! I think my trunk is a little bigger than my last and its not a hatchback. Do you think the same measurements will sound just as good? From what I'm seeing it was 37" x 17.5" x 17.5" tuned to 32hz with 56sqin of port area. As long as it would fit it should be fine. Like I said, if you need it redesigned to fit the new car just let me know. I don't get off work till 2am but i should be off this Friday so ill probably double check my trunk and let you know then.
