  • Replies 100
  • Views 13.4k
  • Ok so 4 mechman 370 elites and a xspower psc60 ordered from the ssa store today. Will be ordering subs soon. Bracket ordered today also
  • liljestrand
    liljestrand
    A smidgen of an update
  • For the old box you had. You said the motors were right above the port? Like blocking the port? Or just covering the back of the sub? What kind of issues would that cause?
When you cut the whole for yhe runs is the in front of the passenger side or driver side back seats
the back seat.  if i would have looked better underneath i could have picked a better spot.  I think i went through a body mount there.
but before cutting anywhere around back there be extremely careful as the gas tank is awefully close to that spot...I had a friend drill through his trying to do this same thing
When you put those batteries under the console, is that vented at all? I want the same exact thing for my main front seat console.
Very jealous of your x2cs, wish I could afford some b2 subs.. Stuck with fi for now
Thats not really a bad place to be stuck is it?
Everytime I open this page and see all that Alternator goodness, it makes me feel some type of way!    Love this build!
Makes me want to beef up my electrical even more lol
Lol no, I can't complain really I love sp4s. But that 5in voice coil though....
Would a 5" coil be good for a music run of 3 mins straight 4k clean power...
  • 2 weeks later...
Hell of an idea to get the enclosure in the vehicle :woot:
Im in love
yeah we needed that lift bad.  480lbs in subs alone plus around 200 in wood.  it was fun enough having to lift it up onto the lift to slide it around.
So across the bottom ports are louder in are year tahoe...
  • 4 weeks later...
I have a ?
When putting 45s in where are you placing them just.in the corners or in the middle or both sides as well
And are you coming off the inside port wall with a 45..KIMG0230_zpsiuwxtsyb.jpg
Where are you tune at just wondering
This is why I wanted his facebook...
  • 4 weeks later...
Sorry I havent been around.  I have 0 45's in my box atm. I am actually in the process of building a new box and getting new amps.  I built that box based on what someone had told me to without running the numbers on the box...basically it came out to like 10 cf with 20 sq in of port per cube tuned to almost 50.  Needless to say it was no where near optimal.  The new box should be more in line with what the subs need.  14 cf with 14.5 sq in port per cube tuned to 38.
and honestly Im not that hard to find on facebook as there are not many liljestrands.
