March 15, 201511 yr Author I think it's just above window line Iirc. But it's under 25" which is what I need for suv for iasca
April 9, 201510 yr 4 Elites, damn that's serious voltage. 800 amps at idle, damn this will be a demo monster
April 10, 201510 yr Author working on the cooling fansmaking a platform for the amps and a platform to raise the amps up to allow the fans below to breathso with the original baffle we ran into 2 problems, 1 I accidently cut the speaker cut outs a half inch too big and 2 the motors for the front subs was right above the port. So to alleviate that we centered the back 2 subs and moved the front 2 subs back.also we need an engine hoist to get this thing out and thats without subs.thats about all i have for updates. will hopefully be able to get more into this in the coming weeks.
April 10, 201510 yr You have a FacebookDont be afraid to ask him on here, I'm pretty sure whatever you need to know could help others on the forum as well.OP build log is getting better and better, box came out way better than mine
April 10, 201510 yr For the old box you had. You said the motors were right above the port? Like blocking the port? Or just covering the back of the sub? What kind of issues would that cause?
April 10, 201510 yr Author The sub was above the port wall. I could barely fit a finger underneath the motor. Thus the vent hole was covered up pretty good. To allow for better cooling I moved those subs back so there is a good 5 inches or so behind the motor
April 11, 201510 yr The sub was above the port wall. I could barely fit a finger underneath the motor. Thus the vent hole was covered up pretty good. To allow for better cooling I moved those subs back so there is a good 5 inches or so behind the motorThanks for clearing that up for me. Was just asking because my box for my zcon is similar to the way you described.
April 11, 201510 yr Iirc the zcon doesn't have a pole vent. So you should be perfectly fine.Nah it doesn't have one. So I'm good. Thats why i was asking incase there was a different reason you changed your box.
April 27, 201510 yr Author Made a center console for the rear buckets to house the batteries. Also has a cupholder and a usb/lighter plug in. B2 hn6 pa mids and id horns.
May 8, 201510 yr Ahh I love b2 idk what it is but I find it hard not be drawn to their products. How do you like the b2 mids?
