Posted February 2, 201511 yr Good ol' pork Chops been on my rear about getting active in here. So here we go.1985 Cutlass supreme build plans. 4 SSA Zcon's In a B pillar Flat Wall Driver side port.Is the set goal in mind of this project.Rear was gutted today and measurements acquired.Designer is in creation mode via Google sketch-up.Building is planned to begin Sunday the 15th! Power currently is a single CT Sounds 7000.1Power goals are two CT Sounds 7000.1's Electrical Currently is a Single Singer 275A alternator.With 1 Stinger SPV70 in the front, And 2 more Spv70'sin the rear along with 4 C&D's in the rear as well. With batteries alone is 410 AH.Electrical Goals are Dual Singer 275A Alternators.With single Battery in front and at least 11 in the reartotaling 800+ AH. Current front stage mid-range Crescendo 10'sTwo in each door. Additional Front stage to be added, super tweetsIn the dash and 3 full ranges in the A pillar. Of course with this massive plan i am extremely anxiousto see how it turns out. Were i'm not trying to rush it,because i want it built correctly and very strong. I have a set goal to be done by Slamology!
February 2, 201511 yr Oooooooo....cutty I remember minds 1984 on 26s with lambo doors post pic if you want
February 3, 201511 yr Author Oooooooo....cuttyI remember minds 1984 on 26s with lambo doors post pic if you wantAbsolutly! Pictures please.
