Posted March 7, 201510 yr i saw in the description of the subs that it was designed for spl but how is the sq? and can it be ran in a daily system without having to worry about the cooling
March 7, 201510 yr i saw in the description of the subs that it was designed for spl but how is the sq? and can it be ran in a daily system without having to worry about the coolingRead this. http://store.soundsolutionsaudio.com/products/judge-15-incriminator-audio-15-2500w-judge-series.html
March 7, 201510 yr ok...and? thats not telling me anythingIt's telling you it's a spl driver that could be used for a daily driver, but your going to lose sound quality because it is built for spl use. Maybe you want a sq driver that can get loud? What is more important to you sq or spl? Go to their website and email them. Not many IA users seem to use this forum. Edited March 7, 201510 yr by pmureika
March 7, 201510 yr Do you like black or white....or perhaps grey. There is no difference in the question. Currently you seek grey but we know not why.
March 7, 201510 yr You asked us something pretty damn subjective. It might sound good to someone else, but you may not like it, or vice versa. You need to have a way of expressing what it is you consider quality sound. If you can't do that, go ahead and buy it anyway, you won't know the difference.
March 8, 201510 yr I want a sub that have the best of both worlds sq and splBesides this what are your goals, budget, space available, power on tap, current electrical etc.?
March 8, 201510 yr I want a sub that have the best of both worlds sq and splThen buy an Icon.If you want a loud sq sub.Spl subs have a very peakish response curve.
March 8, 201510 yr Author I want a sub that have the best of both worlds sq and splBesides this what are your goals, budget, space available, power on tap, current electrical etc.?Daily ground pounder...$1400 for subs and $1500 for amp(s) looking to run about 8k watts trying to try something different than sundown..but I can squeeze 17-18 cubes
March 8, 201510 yr Buy SQ oriented subs and go with a large build. All I can really suggest. Plenty of power, and plenty of room so you really seem to be after spl but staying musical while doing it.
March 8, 201510 yr Buy an SPL sub and play music.Seriously you are making no sense. Either you want a peaky respobse, flat or somewhere in between. Stop using terminology youeont understand
March 8, 201510 yr Author so basically you guys are saying its stupid to want a sub that gets loud and sound good?
March 8, 201510 yr That's why you buy a sq sub that can get loud. Like a ssa xcon or something equiveliant. Read the reviews on the xcon you won,t be disappointed. Edited March 8, 201510 yr by pmureika
March 8, 201510 yr Author I'm not interested in ssa subs..almost every time some recommends a sub 90% of the time it's a ssa sub that's why I asked the question in the IA section
March 8, 201510 yr All we were trying to do is help you understand the difference between a SQ sub & and an SPL subs output.You wouldn't use a washer to try to dry clothes would you?This is why you really can't use an spl sub to play a wide variety of notes equally as loud across a wide range.Nevertheless it's you're money do whatever you want.IA makes quality equipment, your question that you originally asked was misleading to the actual answer you were looking for.
March 8, 201510 yr I'm not interested in ssa subs..almost every time some recommends a sub 90% of the time it's a ssa sub that's why I asked the question in the IA sectionFi Q?? Or I believe the death row is along the same vibe Edited March 8, 201510 yr by puscifer2
March 8, 201510 yr You might try asking icluphf about some first hand experience, though he hasn't been on here for a bit. He is running two 18" judges on an ns1. Sounds about like what you are asking about here.http://www.soundsolutionsaudio.com/forum/topic/62337-incriminator-audio-scion-xb-build-2-18-judges-on-an-ns1/When you ask about the "sq" of a particular driver, it's like saying how well does it work in a "sq" oriented build. You don't seem to want sq, you want loud and sounds good. Loud is easy, sounds good is subjective. We need to know what type of sound you like. What kind of music would you prefer to excel at? What types of setups have you heard in the past? What did you like and dislike about them? What is your budget for electrical? 8k watts worth of amp won't power itself. Edited March 8, 201510 yr by hdrox88
March 8, 201510 yr Author All we were trying to do is help you understand the difference between a SQ sub & and an SPL subs output.You wouldn't use a washer to try to dry clothes would you?This is why you really can't use an spl sub to play a wide variety of notes equally as loud across a wide range.Nevertheless it's you're money do whatever you want.IA makes quality equipment, your question that you originally asked was misleading to the actual answer you were looking for.I apologize if you took my comment the wrong I didn't mean it in a rude way
March 8, 201510 yr All we were trying to do is help you understand the difference between a SQ sub & and an SPL subs output.You wouldn't use a washer to try to dry clothes would you?This is why you really can't use an spl sub to play a wide variety of notes equally as loud across a wide range.Nevertheless it's you're money do whatever you want.IA makes quality equipment, your question that you originally asked was misleading to the actual answer you were looking for.I apologize if you took my comment the wrong I didn't mean it in a rude way Everybody is just trying to help.Lol
March 9, 201510 yr Pretty sure the "sq" of a btl will blow you away. Horrible use of the term, but trying to make a point.
