Posted April 10, 201510 yr How accurate are these calculators?http://www.carstereo.com/help/Articles.cfm?id=31I'm trying to learn box design on my own for my Zcon 15...sorry if this has been covered before.
April 10, 201510 yr Download WinISD. You'll learn a crapton in the process. Before trying to enter the Zcon though Google how as it is really critical of rounding "errors". In quotes as they aren't all that significant, but WinISD will see them as wrong.
April 10, 201510 yr The only other method I'd use is hand calculations. Grab Dickison's book, it's worth it. Buy an old version for cheap The math hasn't changed.
April 10, 201510 yr Author The only other method I'd use is hand calculations. Grab Dickison's book, it's worth it. Buy an old version for cheap The math hasn't changed.I have WinISD,but it don't work right it seems to me. May need to install it again. I was googling how to do it by hand when I found those lolThx M5 Edited April 10, 201510 yr by garychurch84
April 10, 201510 yr Be sure to get the newest version of WinISD (version 0.7.0.900) its much better. You can get it here: http://www.linearteam.org/download/winisd-07x.exe When you try to enter in the T/S parameters of your sub, you will have a lot better results if you do it this way: 1. Enter Mms and Cms This gives fs. If either is not available, then enter fs and other parameter. 2. Enter Sd, Bl and Re Now, you should get all but Qms (and Qts), Vas. Please note that Vas may not match exactly what is specified by manufacturer, because exact value of Vas depends on environmental parameters. See FAQ. 3. Enter Rms or Qms. Either one will do, although I tend to prefer Qms over Rms, because it can usually be measured in driver measurement procedures. 4. Enter Hc, Hg and Pe. If Hc or Hg or either is available, then enter Xmax and optionally either Hc or Hg if available. 5. Enter number of voicecoils. This procedure is most accurate. Also note that it also calculates true SPL (1W/1m) value. So it might not match the marketing SPL value, which is generally somewhat vague. Not in all cases, though. 6. Correct Znom, if necessary. If there are several voicecoils, then you must be careful when entering parameters in that case, because many manufacturers give Bl in voice coils in series, because it yields double value for Bl against parallel connection. If driver manufacturer gives Qes, Bl and Cms or Mms, then you can check how Bl is specified. For that, you can enter following parameters to calculate Re: Qes, Fs, Mms or Cms and Bl. Connection mode can be changed by changing the combobox selection. The driver editor then converts Bl and Re values accordingly. Equivalently, you can check for Bl by entering: Qes, Fs, Mms or Cms and Re (for desired connection mode). If you enter resistance for parallel connection and get about half of advertised Bl, then you know, that Bl was specified that way. Like in Driver-tab in project window, you'll probably noticed the driver icon in bottom of the driver editor window. you can drag the driver object into some project by just dragging the icon.
April 10, 201510 yr I've never seen a version not work right. NEVER EVER use "optimal" as your design though. You must manually put in the iterations you want and then review the response curves to make sure they meet your expectations.
April 10, 201510 yr Author I've never seen a version not work right.NEVER EVER use "optimal" as your design though. You must manually put in the iterations you want and then review the response curves to make sure they meet your expectations.I'll try the steps mentioned above an see where that gets me
April 10, 201510 yr I've never seen a version not work right.NEVER EVER use "optimal" as your design though. You must manually put in the iterations you want and then review the response curves to make sure they meet your expectations.I'll try the steps mentioned above an see where that gets meIn a box
April 11, 201510 yr I also use WinISD, but find the WinISD and Carstereo are very close once you figure out the port area and net volume you wish to use.
April 11, 201510 yr It is pointless to use ANY calculator that doesn't show response graphs. Exception being if you are just building to a manufacturers specific box...but I haven't been able to do that in 20 years lol
April 11, 201510 yr Personally I like to calculate myself over any current enclosure software if at all possible IMO.
April 11, 201510 yr Author I've never seen a version not work right.NEVER EVER use "optimal" as your design though. You must manually put in the iterations you want and then review the response curves to make sure they meet your expectations.I'll try the steps mentioned above an see where that gets meIn a box There it is!! Lol
April 11, 201510 yr I've never seen a version not work right.NEVER EVER use "optimal" as your design though. You must manually put in the iterations you want and then review the response curves to make sure they meet your expectations.I'll try the steps mentioned above an see where that gets meIn a box There it is!! Lol X2.lol
