Posted April 24, 201510 yr Since my local Facebook page I follow won't answer my question, I'll come here. I've blown 3 fuses in the past two days with my crappy amp wire kit. I kept putting off getting a good set of wire because I'm lazy and didn't want to spend money. However, I've decided that I can't put it off any longer. I have a few questions about what I should get. Definitely getting Sky High Car Audio because that's what I've seen work best from friends. I have a Cobalt CB3200 amp powering two RE SXX V2 15's (Also keep in mind I will be upgrading amps when money comes along, so I would rather prepare for that now so I don't have to buy twice the wire). I plan on doing the big 3 since I haven't yet (Yes, I'm killing my car lol), so should I get 1/0 wire or 2/0 for both amp and the big 3? And what size fuse should I get? Thank you in advance, and sorry for the "noob" question. I'm pretty new to the basshead world.
April 24, 201510 yr Whatever you do DO NOT buy CCA. In fact, when I see a manufacturer that offers CCA at all I am highly suspect of value to performance ratio... Fuse to whatever gauge you end up using. The fuse is there to keep your car from catching fire in the event of a short, nothing else...
April 24, 201510 yr Whatever you do DO NOT buy CCA. In fact, when I see a manufacturer that offers CCA at all I am highly suspect of value to performance ratio... Fuse to whatever gauge you end up using. The fuse is there to keep your car from catching fire in the event of a short, nothing else...X2 Only 100% oxygen free copper for conductivity or you might as well be throwing away money ..
April 24, 201510 yr Author Thanks for the responses. So I'm thinking 1/0 OFC and a 350a fuse? That's what I've been seeing around the interwebs, is 350a for 1/0 at 3500 watts.
April 24, 201510 yr For 3500 watts you could probably get away with 250-300 amp fuse if that is all you can find...
April 25, 201510 yr I ran a 300 thru 1/0 on 3500rms, never failed. Worked just fine.This is what i use now
