Badazz buil.... damn all the time put in to this and the outcome is awesome....
  • Replies 223
  • Views 28.8k
Soooooo sexy
  • 2 weeks later...
Some more work being done on the Yukon. Eric R and Daniel P putting the final touches on this week.
What kind of rcas are you running again
Jeebus.  Absolutely awesome.
Definitely a beautiful install. I love the finishing details on the boards that surround the port opening. Gotta love the fine details.
SounDrive Elevated Fidelity
I'm lovin it!
I agree, those are the little things that add up big time in the end.
Amps are wired up. No sound tonight because it is to late.
  • 1 month later...
WOW, I havnt updated this build log. Ive had the Yukon back and done a bunch of work to it.
Installed new headlights and got the bumper cover fairly strait
Took out the dash and painted it with SEM paint, same color as factory.
http://vid1173.photobucket.com/albums/r587/daviddto79/20151011_105315.mp4
My streebeat 3 run, im rising from 1 ohm to 6.6 ohms so i'm losing a ton of power ( that is being fixed )
http://vid1173.photobucket.com/albums/r587/daviddto79/20151010_121923.mp4
I sold one of my 10k's, the other 10k will hopefully follow soon. I will be getting 4 7.5k's and re coning the subs to d1's
Edited by daviddto
hope the changes get you where you wanna be...
Love the headlights.... are they on ebay
I hope so as well
  • 4 weeks later...
UPDATES, I got one 7.5 but returned it to DC because I need to be realistic ( I don't need four 7.5's). I had 3 5k's shipped to my house and one shipped to Jecar so Daniel can build an amp rack. He is going to tie in the wood into the amp rack. I am adding two more runs of 2/0 ground from front to rear and an 8 way 12volt metal works negative battery terminal. I've got a few other little things i'm doing  that I will post later.
  • 4 weeks later...
Been busy at work but i've been able to get a little done on the Yukon. Pulled the box out, cut the baffle, re did my door pods, got a new drivers side door panel, received all 4 5k's and a new front battery.
