Posted December 17, 201510 yr I want to built a box for four 10" Dcons max demissions are 37"W x 15"H x 22"D but can stretch the depth a little. . Im using a rockford T1000 at 1ohm. What is suggestions out there thanks in advance
December 17, 201510 yr Ported optimal is 1.25cuft * 4 = 5cuft. Leaves you no room for a port. Means you get to build a 4cuft or so sealed box and call it a day.
December 17, 201510 yr Admin Unless you already have them or find them used, I believe we are out of Dcon 10's for a little while.
