Posted June 3, 200619 yr $24.44 @ WalmartCheap; but, functional. Edited June 3, 200619 yr by oldschool4life
June 3, 200619 yr Repost or not, this device is teh USELESS. Just to check I looked it up, not even a type 2 like the radio shack (type 0 is most accurate, type 1 is acceptable for measurements in the audible range, and type 2 is +/-8db by 8kHz and rolls off accuracy on the low end too). I'd bet at 50hz this thing is off by more than 10db which would make it uber useful for measuring, it will be way more repeatable than that but who gives if it is that far off. At least the Radio Shack is a type 2, this is just a pos.
June 3, 200619 yr Admin Repost or not, this device is teh USELESS. Just to check I looked it up, not even a type 2 like the radio shack (type 0 is most accurate, type 1 is acceptable for measurements in the audible range, and type 2 is +/-8db by 8kHz and rolls off accuracy on the low end too). I'd bet at 50hz this thing is off by more than 10db which would make it uber useful for measuring, it will be way more repeatable than that but who gives if it is that far off. At least the Radio Shack is a type 2, this is just a pos.
June 3, 200619 yr This is an SLM, oh and an RTA....just can't buy it at Wally world.http://www.bksv.com/default.asp?ID=3153
June 3, 200619 yr This is an SLM, oh and an RTA....just can't buy it at Wally world.http://www.bksv.com/default.asp?ID=3153<{POST_SNAPBACK}>How much ?It looks pretty robust and the spectrum analizer is sweet
June 4, 200619 yr All right, you primitive screwheads, listen up...<{POST_SNAPBACK}>See this? This ....is my BOOMSTICK! The 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about $109.95. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You *got* that?
June 5, 200619 yr Author All right, you primitive screwheads, listen up...<{POST_SNAPBACK}>See this? This ....is my BOOMSTICK! The 12-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about $109.95. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You *got* that?<{POST_SNAPBACK}>Is this the new "fritter"???
June 8, 200619 yr I tried itapparently 6 12's with 3000W can hit 140dB ( stupid thing on the back)And i can blow 110dB.The thing is all over the place too
