looking to buy a saw blade for my circular saw to cut my MDF. i was going to have lowes cut it, but i can't quit worrying that they will mess it up so im going to do it myself. i have been told to get at least a 40 tooth carbide tip blade....i am only going to use this thing once so i dont want to put a lot of money into it. i was thinking getting a higher tooth count blade, just not carbide tipped. i was thinking like a 120/150 tooth blade....would that work well? is the carbide tipped that big of a deal?
ok, i just bought one for $5, 140 tooth, non-carbide. i live in a small town so i dont have much of a selection. i am going to lowes next week so i will check for a carbide one there. thanks for the help though
Carbide tipped tend to leave gouges in the wood if you pull it from the side since the actual teeth are thicker than the actual blade
Yeah, I usually buy the cheap $3 ones from Menards for every enclosure I do. It's nice to have a new blade for every box and they're cheap enough to justify it. They do NOT last though, so if you want to go cheap, that is the way to do it.
$12 carbinde blade with 3/32" with is what ive used for the past 5 enclosures and its still sharp as ever :)
:D
well i went to lowes today and all i found were either 40 tooth carbide tipped blades for $10 or 140~ tooth carbide tipped blades for like $30. i didnt want to spend too much and being only for a one time use, i stuck with my 150 tooth non carbide blade. thanks for the help
you dont need lots of teeth...40 tooth is plenty...you just want to stay aay from ripping blades :)
you will need a new blade soon if you do much cutting on MDF...get the 40 too th carbide next time :)
this box should be the only time i use it, but next time around i will probably go with a carbide. i figured that you would need more than 40 teeth..
nah, 40 teeth is fine, just odnt go below 30 with MDF :)
