What routines do you guys use in your workouts, do you use freeweights or machines, and what exercises and weights???
J
Freeweights, today it was picking up rocks outa a field from a foundation that we buried.  Had enough rocks to squat a 1/2 ton chevy quite badly.
Oh wait, I work on a farm thats my workout.  :D
that can kick ur ass on a daily basis.
j
Guess I'll have to post my full routine. I'll do that tomorrow - hopefully I remember to do so.
I've been lifting for 11 years and am educated in the field.
Good..........i am a kinda sorta flabby 190 and 5'11..........i wanna be 210 and solid by the end of Iraq.
J
Chest/Triceps
Flat Barbell Bench Press
Set 1 : 275 x 8
Set 2 : 295 x 6
Set 3 : 315 x 4
Decline Barbell Bench Press
Set 1 : 255 x 8
Set 2 : 275 x 6
Set 3 : 295 x 4
Incline Dumbbell Press
Set 1 : 100 x 6
Set 2 : 105 x 6
Set 3: 110 x 6
Weighted Wide Grip Dips
Set 1 : 90 x 6
Set 2 : 90 x 6
Close Grip Bench Press
Set 1 : 185 x 6
Set 2 : 195 x 6
Set 2 : 205 x 4
Tricep Press Down (Cable, straight bar)
Set 1 : Stack+25 x 8
Set 2 : Stack+35 x 6
Set 3 : Stack+35 x 6
*Tricep Press Down (Cable, rope attachment)
Set 1 : Stack+10 x 6
Set 2 : Stack+10 x 6
*Skullcrushers
Set 1 : 108 x 6
Set 2 : 108 x 6
* - superset
I change up the press exercises often ... switching from dumbbells to the barbell. Dips hit the triceps and chest hard, it'll all depend on the angle you're leaning at.
Shoulders/Traps
Seated Military Press (Barbell)
Set 1 : 155 x 6
Set 2 : 165 x 6
Set 3 : 175 x 6
Seated Dumbbell Shoulder Press
Set 1 : 65 x 8
Set 2 : 70 x 6
Set 3 : 75 x 6
*Weighted Wide Grip Pull Ups
Set 1 : 25 x 8
Set 2 : 25 x 8
*Lateral Raises
Set 1 : 30 x 8
Set 2 : 35 x 8
* superset
Upright Row
Set 1 : 100 x 8
Set 2 : 110 x 6
Set 3 : 110 x 6
I like to toss in a variety of exercises the end ... power cleans, shrugs, etc ... minimum 6 sets and two exercises.
Back/Biceps
Seated Cable Row
Set 1 : 180 x 8
Set 2 : 190 x 6
T-Bar Row
Set 1 : 135 x 6
Set 2 : 155 x 6
Set 3 : 175 x 6
Wide Grip Pull Ups
Same as above, no superset.
Lat Pulldowns
Set 1 : 160 x 8
Set 2 : 170 x 8
Set 3 : 180 x 6
One Arm Dumbbell Row
Set 1 : 95 x 6
Set 2 : 95 x 4
*Standing Alternating Dumbbell Curl
Set 1 : 60 x 6
Set 2 : 65 x 4
*Standing Alternating Hammer Curl
Set 1 : 55 x 6
Set 2 : 60 x 4
* superset
Preacher Curl
Set 1 : 88 x 6
Set 2 : 98 x 6
Set 3 : 108 x 4
Barbell Curl
Set 1 : 95 x 6
Set 2 : 105 x 6
Set 3 : 105 x 4
Legs
Squat
135 x 15
225 x 6
245 x 6
275 x 4
255 x 6
Seated 45* Leg Press
360 x 8
450 x 6
450 x 6
*Standing Calf Raise
225 x 10
225 x 10
225 x 10
*Seated Calf Raise
155 x 10
165 x 10
165 x 10
* superset
Leg Extension + Leg Curl
Wherever the pin falls x 8 x 2 sets (after 5 sets of squats I want t0 GTFO of there anyway)
Not running at max due to my healing back. Plenty of exercises out there for you to do ... mix it up a little bit, find what works with you and stick with it for a while. There is abdominal crap mixed in there of course. I change up the routine often (weight, # of sets and reps, the actual exercises) as my body adjusts, adapts, and really gets used to the same routine over and over again.
http://ast-ss.com/training/exercises/eow-intro.asp
http://forum.bodybuilding.com/ --- read, search, read some more.
The best supplement you can take is food. Seriously. Every 2.5-3 hours, high quality meals. Tough to do while you're in the military/training.
the ONLY thing i am remotly ur level on is calf.............i do 195 standing and 160 seated 3 sets 10 reps of both......leg press i'm doing about 170
J
Free weights when i do lift
rest of the time, running long distance, 400m's, stadiums (doing laps around the stadium up and down the stairs), push ups and sit ups and doing chores around the house...
When i do use freweights my lifts of choice are benchpress, over head press (when my sholder isnt bothering me), Clean and Jerk, Squats, Calf lifts, and i use the lat machien (pull downs and upright rows).
i usually do low weight high rep an everyonce and a while a pyramid workout.
