Posted June 24, 200620 yr closedopen im tie each rack to each door. so when you the left or right a door, that right or left amp will come up at you.
June 24, 200620 yr can i have sex with your car?I believe you are the reason they started putting locks on gas tanks.
June 24, 200620 yr So are you using some sort of micro switch on the door to control and actuator? I'd really like to know the idea behind this and how you're going to implement everything. Looks great!
