July 3, 200620 yr Looking for LSQ. I have a RL-p 12 and love it but wanted to take up less room. I thiknk I might port what I have built with 2" PVC. I will run the ports outside the box. I just to find out if 2 " is big enough or will I get a lot of port noise. I do have mine faceing the rear of the car.
July 3, 200620 yr I guess I am getting old. I find my setup great. I can feel the music and the SQ it excellent. I am sure if I rear-fire the box I will love it due to the additional output. I wanted to keep my box in the current location as it does not take up too much room.What would be the port specs using 3" PVC for 2 8's in a .828 cu^3 (after sub displacement)?ThanksLooking for LSQ. I have a RL-p 12 and love it but wanted to take up less room. I thiknk I might port what I have built with 2" PVC. I will run the ports outside the box. I just to find out if 2 " is big enough or will I get a lot of port noise. I do have mine faceing the rear of the car.<{POST_SNAPBACK}>
July 3, 200620 yr I had 2 2.25" ports on my RL-i 8Had some wicked port noise.But when in the trunk with the set up you couldnt hear it.That sucker was loud though.Sounded like a sealed 10
