September 20, 201610 yr Change the surface area of the port (port size) when modeling and see if it helps the peak.
September 20, 201610 yr Also make sure the scale isn't exaggerating things. It is amazing how bad ears are at discerning small differences in volume that when scaled wrong on a plot look HUGE.
September 20, 201610 yr Author 39 minutes ago, j-roadtatts said: Change the surface area of the port (port size) when modeling and see if it helps the peak. i tried a 6 inch port and still the same Edited September 20, 201610 yr by FiAudioSubwoofersjj
September 20, 201610 yr You could shift the port tuning a few hz and see what happens to the peak. Maybe give 30hz and 35hz a try. Beyond that, I honestly think your graph looks pretty good. One of the goals with a ported enclosure is to gain output in the intended bandwidth, which your design is clearly doing. If you want a smooth response, perhaps model sealed.
September 20, 201610 yr Author 2 hours ago, j-roadtatts said: You could shift the port tuning a few hz and see what happens to the peak. Maybe give 30hz and 35hz a try. Beyond that, I honestly think your graph looks pretty good. One of the goals with a ported enclosure is to gain output in the intended bandwidth, which your design is clearly doing. If you want a smooth response, perhaps model sealed. so should i go and build my original design? 2 4 aeroport (i do not have long enough 6 inch pipe) tuned at 33 in a 2.5 cuft box?
September 20, 201610 yr Popular Post I would be happy with it, if thats what your asking. With the transfer function of the car you should be right on point, and the sub should blend well with the mids. Youre gaining 6db output in the sweet spot, WITHOUT needing any additional power. Whats not to like about that?
September 27, 201610 yr I'd choose the single six inch port. I think you said you already have it, and it presented the best port velocity
September 28, 201610 yr Author 5 hours ago, SpeakerBoy said: I'd choose the single six inch port. I think you said you already have it, and it presented the best port velocity Yea I have 1 6 inch in diameter but it's only 15 inches long and is super heavy because the pipe is from a plumbing store and i need around 22 inches in length
September 28, 20169 yr http://www.parts-express.com/precision-port-6-flared-port-tube-kit--268-354 buy two of these. One full length is 18", you can cut the second tube to add to the length you need for the tuning you are trying to achieve. These are much lighter then your current tube.
