Posted August 5, 200620 yr Hi All,Ok, so a few of you mentioned that a 4 Ohm version of the MJ-18 would be in order. It is coming close to my order time, so a batch of these can be included with the main order.I do however, need some commitment from those who are planning on going with 18" drivers in their setup and are strongly considering an MJ-18 (read buying one).Here are the particulars to this:- The 4 Ohm version will have very similar parameters to the MJ-18. I will request that a sample be made and measured to verify. Any changes in specs will be posted here for all to see.- Consider the price of the MJ-18 to be the starting point - $59.38CA. If I can get it lower, I will, and you will save.- Lead time is ~2 months. Please keep this in mind when deciding. I will keep you in the loop of any changes or adjustments. Also keep in mind that changes in lead times are beyond my control, so please don't get discuraged if it takes an extra week - you will get your product. - I would like to see a $20 non refundable deposit from those who are interested. Payments can be made thru PayPal using [email protected] as the recipient. I will require your full name and mailing addy to keep track of things.- The more the merrier, so spread the word.If there's anything I missed, let me know.Best regards,Mark
August 5, 200620 yr Hi All,Ok, so a few of you mentioned that a 4 Ohm version of the MJ-18 would be in order. It is coming close to my order time, so a batch of these can be included with the main order.I do however, need some commitment from those who are planning on going with 18" drivers in their setup and are strongly considering an MJ-18 (read buying one).Here are the particulars to this:- The 4 Ohm version will have very similar parameters to the MJ-18. I will request that a sample be made and measured to verify. Any changes in specs will be posted here for all to see.- Consider the price of the MJ-18 to be the starting point - $59.38CA. If I can get it lower, I will, and you will save.- Lead time is ~2 months. Please keep this in mind when deciding. I will keep you in the loop of any changes or adjustments. Also keep in mind that changes in lead times are beyond my control, so please don't get discuraged if it takes an extra week - you will get your product. - I would like to see a $20 non refundable deposit from those who are interested. Payments can be made thru PayPal using [email protected] as the recipient. I will require your full name and mailing addy to keep track of things.- The more the merrier, so spread the word.If there's anything I missed, let me know.Best regards,Marki'm in.will paypal tomorrow when i have some time.
August 7, 200620 yr I'd be in, but my paypal account is not working. any other way I can get the $20 deposit to you?
August 12, 200620 yr Author Hi,The deposit will be based on per driver - if you want two, send $40.If PayPal doesn't work for you, just mail a cheque to me - my mailing addy is on the site under 'About Us'.Best,Mark
August 27, 200620 yr so we're looking at the end of the year to get some in?i'm thinking about 4...in my civic...IB...i'll probably get in on it closer to the end of the cutoff...
August 27, 200620 yr Author ** Update **A MJ-18 4 Ohm sample will be made up and measurements taken by the OEM in about a week. If all turns out well, and consensus here is positive, a run of them will be done and shipped here in about 7-8 weeks.Thanks,Mark
