Posted August 6, 200620 yr What's the bigges guage I can shove into the MD2's outputs with out having to trim the wires?I gotta know when I go buy power...err speaker wire.
August 7, 200620 yr Author Output mang .I think ill see if the 8ga power wire i have laying around will fit. If it does Im gonna go pick up some 8ga wire from lowes. Cheap and effective.I hope the terminals on the speaker I'm getting will accept 8ga.
August 7, 200620 yr I think 4 guage... I had to trim the 0 gauge i'm running of course...<{POST_SNAPBACK}>A big no-no in my books.Use a reducer.
August 7, 200620 yr If you use KnuKonceptz Kolossus 1/0 you have to trim it. It doesnt even fit in a reducer.
August 8, 200620 yr Nothing wrong with trimming wire 0 guage is more than enough as is unless u will be running a consistent 3000 watts which most don't...
