Posted August 21, 200619 yr Another round of testing done this past weekend. This time, using the MJ-18 in a 250 litre Sono-like tube. Check it out if you have a moment:http://testbed.mach5audio.comBest regards,Mark
August 22, 200619 yr Author Around $55CA give or take a buck - about the same for the equivilency in MDF. But I was able to bang this off in an afternoon, whereas it would take a couple of days to build a box.Best,Mark
February 26, 200719 yr My MJ-18 is en route and will be placed in a 8.8 cu ft enclosure made out of 13ply plywood. I am curious if the 18" proto will fit in as a replacement when it comes in?
