Posted August 23, 200619 yr ok so i dont know what the settings should be on this amp so i was wanting to know what suggestions you guys had that i should set them on cause i will be installing this in the morning.here is a pic of the side,if you click on it you can make it bigger and get alot better view if the settings.http://www.limelighthosting.com/~dave/MK800.4/IMG_0986.JPG
August 23, 200619 yr Gain= you can either use the Gain setting tutorial or do it the old fashoned wayXover= HPFSub Sonic= automatically shut off when switched to HPFLPF= Automatically shut off when switched to HPFHPF= kinda have to guess, set it in the 80hz rangeBass EQ= dont touch it, 0dB
August 23, 200619 yr Author so im not gonna be messin with the LPF at all???....i thought it was the HPF that you really didnt mess with???
August 23, 200619 yr This is for a front stage, correct?You won't be concerned with subbass, so you can use the HPF...
August 23, 200619 yr Admin so they are correct, HPF is what you want, make sure the bass boost is all the way down and check the gain setting tutorial on here, it will help give you a good basis these are suposed to be very well built amps so take care of it
August 23, 200619 yr Author what test tone can i download and use to set the gain on my 4channel???... the 1khz sine wave one??? Edited August 23, 200619 yr by natedizzle
