Posted April 1, 200422 yr Just want to wire a friends two under-dash neon's and one under the back seat to a single toggle switch mounted on the dash.Battery ---> power wire (16ga) ---> inline fuse (5amp) ---> more power wire ---> 12v power on switchAcc on on switch ---> neon x3 (splicing all together to run off the single switch)Ground switch and tube.Right? Wrong? Your feet smell?Perhaps just using the cigarette lighter in the car. Cut the wires off the back of the lighter in the dash, cut the DC adapter off of the neon, wires from lighter into switch ... ? Probably the easiest way if it works ...Thoughts and opinions. Going for simplicity.- Steve
April 1, 200422 yr I would probably say 20a to be on the safe side. I had some neons on my bug when i use to drive it, and i put a 20a fuse on there, it was fine, worked nicely too.Gotta love switches, i have switches on each of my amps right now, yea its only for the remote, but it does help when you just want to listen to the radio and not have the sub amp going.
April 1, 200422 yr Author So I take it that idea would work then.Cig lighter wires would have been easier, oh well.- Steve
April 2, 200422 yr Author Sooooooooooooo any other thoughts / opinions ...Haha ... I laugh @ the Iron Chef ... SQUEEEZONNN - Steve
April 20, 200422 yr Author Update ---- We blew up $250 worth of neons.I'm not a happy camper. Actually, I've right the fudge pissed off if you really want to know it.- Steve
April 20, 200422 yr Author If I knew for sure, I'd tell you.But I'm stumped. And so are two certified mechanics. I bet it's something small we all overlooked.I tried to call you ... some lady on an answering machine ?- Steve
April 20, 200422 yr Admin umm do you have to dial an international prefix to call the US?my cell is working fine as far as I know
