January 31, 20179 yr Admin There are still so many W123's and W124's running around this city. My sister's W124 is still rolling along. I still want another.
February 1, 20179 yr Author 4 hours ago, Aaron Clinton said: How much to get it here: [/img] That specific one was on ebay for $189K, EVO II are really rare http://jalopnik.com/you-can-own-this-mercedes-190-2-5-16v-evolution-ii-for-1775715137 41 minutes ago, ///M5 said: Needs the wing off and new wheels....but I WANT But they are period correct and came on all EVO II
February 2, 20179 yr Yes. But you know me, way too cheap to spend $200k on a car in particular when you can build a better one cheaper. Then I would have different wheels and no wing.
February 2, 20179 yr Author So amplifier changes have changed already. I had a US Acoustics Barbara Ann laying around. I am going to use it, I also just purchased a Lisa to pair with it.
February 2, 20179 yr 24 minutes ago, S.DeYoung said: So amplifier changes have changed already. I had a US Acoustics Barbara Ann laying around. I am going to use it, I also just purchased a Lisa to pair with it. What, are you new ??? Pics homie !!!
February 2, 20179 yr Author 45 minutes ago, Randal Johnson said: What, are you new ??? Pics homie !!! I'll take some when the Lisa arrives. For now, links: http://store.soundsolutionsaudio.com/products/us-acoustics-barbara-ann-400w-4-channel-amplifier.html http://store.soundsolutionsaudio.com/products/us-acoustics-lisa-4-x-50-watt-amplifier.html
February 3, 20179 yr Nice Amplifiers. One on a pair of SSA tweeters flush mounted in the dash and one on a pair of SSA 6.5s in the doors would make for a bad ass setup !!! Just Saying
February 3, 20179 yr Author 15 hours ago, Randal Johnson said: Nice Amplifiers. One on a pair of SSA tweeters flush mounted in the dash and one on a pair of SSA 6.5s in the doors would make for a bad ass setup !!! Just Saying I will for sure try the new tweeters, depending how far I get with the rest of the install by the time they come out they may be install first. The Evil 6.5's will be installed into the kicks. This car does not come with door speakers factory, I thought it would be easier to add woofers in the kick panels rather then in the doors.
February 3, 20179 yr Gotcha. I read that about the kicks. My bad. But yeah, You knew what I meant anyways. Carry on brother
February 10, 20178 yr The headline said in...I eagerly clicked thinking that meant in the car. Glad you aren't that fast as I would feel even lazier
February 20, 20178 yr Author Popular Post More progress: Amazing weeked here in Michigan. High 50s to low 60s all week. Tearing some of the interior out demoing previous owners lovely work: Old Alpine MRV under the rear seat Spray foam and cheap wooden boards screwed down into the trunk floor. Lovely. Bondo to fill holes?
February 20, 20178 yr Author 10 minutes ago, Tirefryr said: OMG, they used spray foam for mounting?! Spray foam for mounting and bondo for sealing around holes.
February 20, 20178 yr 1 hour ago, Tirefryr said: Yeah, but it will melt ABS and PE though, and I think that insert is HDPE. I thought it was painted metal, sorry.
February 20, 20178 yr Author 7 hours ago, nem said: I thought it was painted metal, sorry. That is painted metal, its the spare tire/trunk floor. Most of it just scraped off. I will be using some acetone based solution to remove the rest of it. Either way this is going to be covered. I am thinking about using the Second Skin Sludge to deaden this area and then I will be building a spare tire enclosure for the DCON or GCON.
