September 1, 20179 yr Author this Is what I got from Bassbox. Driver Properties Name: ICON 15 D2 Type: Standard one-way driver Company: Sound Solutions Audio Inc. Comment: ICON series No. of Drivers = 1 Dual voice coils = parallel Fs = 26.8 Hz Qms = 6.6 Vas = 4.241 cu.ft Xmax = 0.827 in Sd = 125.6 sq.in Qes = 0.49 Z = 1 ohm Pe = 1250 watts ----------------------------------------- Box Properties Name: Type: Vented Box Shape: Prism, slanted front Vb = 5.418 cu.ft Fb = 22.7 Hz QL = 5.612 F3 = 24.57 Hz Fill = none No. of Vents = 1 Vent shape = rectangle Vent ends = two flush Hv = 14.25 in Wv = 3.5 in Lv = 45.57 in
September 1, 20179 yr Maybe you can try a bandpass enclosure ported through that opening. Normally wouldnt suggest a bandpass but mite help out with your situation
September 1, 20179 yr Author Lol! that was my original plan with 2 10" soundqubed hdc3.110. Kind of a band pass blow through. I kind of got talked out of it on another forum. Also got pointed away from the soundqubed and to the ssa icon. I got away from 2 10"s to one 15". Funny it is almost full circle again. That being said I am not going to rule it out. Won't it require more space though? Edited September 1, 20179 yr by ScotnEmily
September 1, 20179 yr Author Actually I was going to do 2 8" subs in the beginning, but was afraid I would not get the bass I waned, so I changed it to 2 10" subs. I have a few different blow through box ideas, but the one above is the one I was leaning towards the most. another had the subs facing the same but the port came out between them. another they were facing each other. You get the Idea.
September 1, 20179 yr Get 2 10s or 12s Xcon and have fun ! Sealed or ported, you'll love them. Icon or Xcon ? I've tried both, and loved both...but get the Xcon(s) for that 740.
September 2, 20179 yr Author Thanks I will definitely consider your advice. Do the calculations I posted above from bassbox look ok? Do I need to change box size, or port tuning on it any?
