Posted March 5, 200719 yr ok, i got my two 18" BLs in a box i built, designed by TTB. this box is like 10cf gross. it is small. i am sorta dissapointed. need a bigger box.i would like subs up and port back tuned to 32-34hz. my desired outside deminsions are 42.5 wide x 24 tall x 28 deep. i will add the top double baffle making it just under 25" tall. can anyone help with this?email - [email protected]
March 6, 200719 yr Here is a box near what you asked for. Copy and paste the address, good luck. The program goofs up if port is too close to rear of box, you can change port size by changing woofer Xmax or tuning freq, or box size.http://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0link to box plan
March 7, 200719 yr is it too much high bass for u? just hit me up man anytime id be glad to help you. im also running 2 18" bls
