Posted June 1, 20188 yr I currently have two HDS3.1 10s.. My baby steps are going to build 4th order wall.. I have chevy sonic 2015 hatchback.. The 6 subs will be inverted inside port wall.. I will be working on the back seat out for measuring spaces.. Depends on my taste build.. It probably will be done by a yr or two.. Anybody can dream it even low on budget.. First is get a mids and high front stage.. Of course it's going all soundqubed products.. The amp will be 4500 rms.. And three batteries in back.. I will upload into photobucks.
June 1, 20188 yr More logical to just build a standard ported box. Still get the 4th order roll off and will work out better.
June 4, 20188 yr Author On 6/1/2018 at 3:14 PM, ///M5 said: More logical to just build a standard ported box. Still get the 4th order roll off and will work out better. I can try that and see..
June 4, 20188 yr If you had some compelling reason for the bandpass we overlooked perhaps it is ok, but usually it is a net negative.
