Posted June 3, 20188 yr I want to build a box or maybe 2 with the 18" judge series subwoofers. Would these work well tuned @ 20hz? What would the size of the box be for a tune at 20hz?
June 3, 20188 yr Author How would the Incriminator audio 18" Judge series do in a large box tuned at 20hz for home theater? Edited June 3, 20188 yr by clodbuster2017
June 3, 20188 yr I've merged your threads as they can both be answered in one shot. Why do you want to use these drivers for home theater? Neither are designed for that application. You need to be looking at purpose built drivers or something that will be a compromise if you absolutely need to. There are hundreds of HT spec'd drivers that will do what you want and you can find something for nearly every budget.
