WHAT'S OHM ARE THE SUBS????
______________Ampere 5k is strappable at 2ohms __________
3 1ohm 18s wired in series, Parallel gives you 0.67 ohm load OR Parallel, series gives you 1.5 ohm load
3  2ohm 18's wired in series, Parallel gives you 1.34 ohm load OR Parallel, series gives you 3 ohm load
3 4ohm 18s wired in series, Parallel gives you 2.67 ohm load
Hope this helps
     :google:
I ran an XCON 10" on a 500 watt Rockford Fosgate T-500 and it sounded great.  I upgraded to a T-1500 and it sounded great and got louder.  You can run 3 18" ZCONs on a 5K and it will sound great IF your box is designed and constructed well, but you won't be getting full potential on 5K watts.
15 hours ago, Randal Johnson said:
Op said a pair of 5ks brother
I teach economics and history, NOT reading.  hahahahahaha, my bad.
  • Admin
Yes, a trio can handle that power no problem.
