Posted August 22, 20196 yr I have a problem with my mtx 12s everything is hooked up but when I press the gas the subs go off and i thought it was the fuse it was hooked to but i switched the fuse and it kept doing it so I took it off the fuse and left it off but I started driving home and the subs kept going off what could it be I need help
August 23, 20196 yr Do you mean your amp is shutting off? Like, you accelerate and the amp cuts out? If that's the case, it sounds as if you have a loose connection and it's exacerbated by the movement from accelerating.
