Posted April 27, 20205 yr I have researched and researched but I cant seem to figure it out Cadillac CTS, stock Bose system, stock amp/10 inch subwoofer that has a bump that's not bad However I would like a tiny bit more bump I'm wondering if I can just replace the stock sub with an aftermarket one Any help will be appreciated Thanks Edited April 27, 20205 yr by john27 =
April 27, 20205 yr With just swapping out the driver you're still limited to the stock enclosure (which won't be optimal for the new driver) and the same amount of power. It will not yield a noticeable difference, unless the new driver is crazy efficient in comparison, which you won't find. If you want more, you're going to need to upgrade more.
