Im switching amps and am intersted in the sundown Sfb-3000d. My question is can I hook up a dual 2ohm(wired down to 1ohm) to each +/- terminal for a total of 2 subs on one Amp?  Any help is much appreciated.
 Yes you can but I wouldn't do it. With two Dual 2 ohm subwoofers your final load will either be 0.5 ohms or 2 ohm's going to amp. So you will want to find an amplifier that does the power you want at 2 ohm's to conserve the life of the amplifier. For burping I would do 0.5 ohm load but not for daily use. But that's my preference personally
