Posted March 11, 200718 yr this amp does over 800rms from 4-1ohm making it VERY versatile. it's small and can fit all over, it has SICK on board xovers/subsonic, 24dB per octave I believe, built in cooling fan. just over built in general and a sick amp. I always see people going with other amps because they just don't know what they're missing... see the vid in my sig of one x600.1 pushing a single DD 9510F and tell me another budget 600watt amp that'll do that.. I'll propmtly reply with a good smiley from another forum
March 12, 200718 yr Admin It is a great amp, I dont understand the reason behind killing off the Xenon line.
March 13, 200718 yr I love my Xenon 200.2 and 100.4 for my front stage... Too bad they didnt make a big amp for my substage
March 14, 200718 yr You might be able to find a X1200 floating around out there.I know, but I'd want to run at least a couple, if not 3 or 4
March 14, 200718 yr They are great amps, but I was told by a friend with Carver that there was a conflict between PG w/ their Xenon line and JL Audio w/ their R.I.P.S trademark.
March 14, 200718 yr A couple. Ill probably just end up getting an Orion 2500D, talk about cheap power!
March 15, 200718 yr Admin A couple. Ill probably just end up getting an Orion 2500D, talk about cheap power!I think it is one of the better sub stage amps I have had. I use it now for all my testing.
March 16, 200718 yr Author They are great amps, but I was told by a friend with Carver that there was a conflict between PG w/ their Xenon line and JL Audio w/ their R.I.P.S trademark.then they should have removed the xeLoad since the amps do WAY sick power without it, and just make them stable to run 1.3ohms without xeload and a pair of strapped x1200.1ds would DESTROY An orion 2500d thanks... output would just be wasted... and as far as quality lol I won't even get into that... I sold my hcca5000d locally for $450 bnib.. my 1200d I still have and use.. but I prefer the x600.1 over it. and my old xtrpro 2400d... I'd WAY rather have a pair of x1200.1's over... 4ohm per they'd be better lol. and yes there is a way to strap them before anyone opens their mouth that doesn't know what they're talking about... it takes a module which has been available for years before the xenon's came out... and a pair of 1200s will do alot more that 2400rms we'll leave it at that and my 141.9@34hz is from a jetta trunk legal new TL off a single x600.1 with the bypass done via switch in speaker + lead. it gained a little over a dB I think... don't remember didn't test with xeload in a long time lol... I'm running it 2ohms so after imp rise I'm probably 4ohm or higher... so it'll still see only 800ish rms or less but I don't want to load it lower incase it cooks.. but it definetly does enough power imo lol Edited March 16, 200718 yr by HawaiianBassHead
