Posted March 20, 200718 yr for my next setup im thinking about possibly doing either 2 18" BL's or 2 18" BTL's, i know it would be much easier on my electrical system running two BL's rather than 2 BTL's. but i have a couple questions. first is 2K RMS enough for each fully loaded BL ? second, would a BL get louder on 2K RMS than a BTL ? and third does the BL have better SQ than a BTL ? thanks in advance
March 20, 200718 yr To be straight...you can't power 2 BLs like they want with a stock electrical system.I say get a new alternator, some xtra batterys, and a couple BTL's.
March 21, 200718 yr Author i was never going too...im gettin a 300 amp alt from iraggi, but what i was insinuating is that 8K RMS is going to make any electrical system work much harder...but no im nowhere near dumb enough to try and power 4k rms out of a stock electrical thats flat stupid..
March 21, 200718 yr "i know it would be much easier on my electrical system running two BL's rather than 2 BTL's."What difference does the sub type matter? It's all about the wattage. 2kw to a bl is the same as 2kw to a btl.So...2kw is too much for bl's (so I've heard). But it's great for btl's.300amps...how many batterys?
March 21, 200718 yr With a BL and all options it should handle 2K with no issues....Actually the subs can make a difference on the electrical being if one sub is more efficient then the other.... but it wouldn't be the sub DIRECTLY impacting the electrical but the amplifier.. a less efficient sub will push an amp harder than a more efficient sub... So you can't say 2k on a BTL is the same as 2k on a Bl without any influx on the electrical... But dopey you are correct in that the sub doesn't directly affect the electrical but rather the amps do...
March 21, 200718 yr Author because if i did a BTL setup i would power each one with 4k and if i did a bl i would power with 2k.... so that is where the elctrical system comes in... and secondly i was just curious as to effiiciency of the bl vs btl out of sheer curiosity
March 21, 200718 yr Trey that would depend on the amount of wattage and options you get...even the enclosure impacts a subs efficiencyI suggest you contact staff of FiThat type of question should b asked to nick, shawn or scott directly nick and shawn are fast to reply so either Email nick or pm shawn) Edited March 21, 200718 yr by theabunai
March 21, 200718 yr Author thats cool no biggie, but what i really am trying to figure out is how the BL perofrms in the SQ dep ? i know its between the Q and BTL, but does it retain sq even at higher volumes, because i know a lot of good spl woofers lose control when you really push them and notes become less transient and blend together
March 21, 200718 yr BTL 18" Spl: 94.9dB 1W/1m | 95.1dB 1W/1mBL 18" Spl: 92.5dB 1W/1m | 92.6dB 1W/1mThe Fi website says the BTL is more effecient.
