Posted March 23, 200719 yr i was wondering if they could do a 18" BTL with dual 4 ohm vc Edited March 23, 200719 yr by petey
March 23, 200719 yr there is no need for a dual 4 really. what ohm load are you shooting for? you can get .5, or 2 from the dual 1. or 1 and 4 from the dual 2. a dual 4 would get you either a 2 or 8 ohm load. you can get the 2 from a dual 1. and 8 ohm is normally only used in home audio. but you never know. email them and see.
March 23, 200719 yr As stated above, a dual 4ohm really isn't needed. The dual 1ohm and dual 2ohm versions cover all necessary +12v impedances.nG
March 24, 200719 yr Author i need dual 4 because i plain on runin one amp to each vc and my amp does 1000 rms at 4 ohms briged
March 24, 200719 yr you be better off selling that amp and using the money to buy 1 large amp.i speak from experience. i did something similar using 2 4 ohm amps on a large woofer. i set the gains with a DMM so they shouldve been really close. but there were differences in the amps and one side was over powered which killed my sub's surround a few months later. but hey, recones are cheap. do what you will.
March 24, 200719 yr i need dual 4 because i plain on runin one amp to each vc and my amp does 1000 rms at 4 ohms brigedUnless you can strap that amp, thats usually not a good idea for a daily driver setup. And if you can strap it, you should bridge it at 8ohm if they are 4ohm stable and 4 ohm if they are 2 ohm stable. If you need it for spl, you need new amps that make more power. imowhy not dual q's or ssd's? Edited March 24, 200719 yr by dopey
