Posted March 29, 200719 yr i did some measuring and the biggest i can go is 4.5 or less.. so ill have to get a bl 15 instead of the 18 that i had planned.. and i plann on getting a hifonics 1606. box tuned to 32. what you guys think. should i get any of the options.heres the box i gothttp://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0 Edited March 29, 200719 yr by alaskanbass
August 1, 200719 yr i did some measuring and the biggest i can go is 4.5 or less.. so ill have to get a bl 15 instead of the 18 that i had planned.. and i plann on getting a hifonics 1606. box tuned to 32. what you guys think. should i get any of the options.heres the box i gothttp://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0just get the p chamfer and ull be finei have a kicker zx1000.1 and im goin be puttin a 15" (mabe an 18"). that amp is rated at 1258 wattsand evryone that ive asked said that 1200-1400 watts is fine for just daily driving
August 2, 200719 yr is that website acurate with the tunning?? don you have to substract the subwoofer displacement
August 2, 200718 yr No, the program takes into account driver displacement, so the numbers are correct. Only real issue with the program is the fact that port area is based off of Xmax so you dont have a simple way of overriding their sizing/recommendation. Id say youd be fine with just the pole chamfer as well if its only doing 1250W. More, and Id look to the cooling or flatwind to pick up the balance.
