Posted April 4, 200718 yr What it says, I have an oppurtinity to change the subs out. I have ~2000rms to work with per sub, just curious which one would be louder and if the DMXs can get low, cuz the BLs don't get the lows I want.'
April 4, 200718 yr Author Well they don't have ALOT of play on them but the suspension is WAY looser than it was when i first got them.
April 7, 200718 yr your tuned to 32hz, have 2.4 per driver and your not hitting the lows? just what lows are you aiming for? with 2k per driver on top of that?! i'd wager there is something other then subs causing your issue. did you remove any and all insulation between your trunk and cabin? ( i'm assuming this is in the caddy) how much port area? and just how much playing time?if a pair of 12's like the BLs aren't dropping low enough in that setup, i'm not for sure any 12 will. you might just need to step up to a 15 or two. maybe an 18. btw, got a link to the dmx?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
