Posted April 4, 200718 yr Hey guys.I plan on purchasing two 12" Fi BL's. I will be powering them with two NINe.1 amps.....those are my plans. any other suggestions for amps are welcome. But the NINe.1's fit my bugget perfectly.I need suggestions for a box....Ive been messin around and came up with this box. I will 45 all of the corners and seal her up tight. Should this box pound alright, but still sound dec.?? thankshere's the link http://www.subwoofertools.com/forum/ported...;Fs=27&CE=0
April 5, 200718 yr Should do fine. Id only put the 45 in the port corner and the run a radius on the inner outer edges of the slot port (thats if I was to even go that far).Should sound fine.Thanks,Scott
April 5, 200718 yr Author Should do fine. Id only put the 45 in the port corner and the run a radius on the inner outer edges of the slot port (thats if I was to even go that far).Should sound fine.Thanks,Scotto alright, i'll do that.thanks.
