Posted April 9, 200718 yr I have this amp and it says 600 watts @ 4 ohms.I know it has more power than this I just dont know how much. If anyone knows the specs on this amp it would be helpful. What ohms is it stable to? What should I fuse this amp at since it has no fuse on it? Does it have an unregulated power supply? Class ? It is an oldschool amp but I would like to run it, just need some info. It was made by ZED audio . I have searched the internet but found limited info. Any help would be appreciated.
June 18, 200718 yr Which one do you have the original blue one or the later revision white one?I have the original manual for the blue one...Stereo (11.5 - 14.4v)300 wrms x 2 @ 4 ohms 450 wrms x 2 @2 ohmsMono (11.5 - 14.4v)600 wrms x 1 @ 8 ohm 900 wrms x 1 @ 4 ohmTHD ( 10 hz - 150khz) 4 ohms- 0.015%2 ohms - 0.15%Damping Factor - 200Input Sensitivity - 200mv - 1 volt @20k ohmsChannel Seperation - >80dbSignal/Noise - 102Slew Rate - 45Idle Current - 1.2 AmpsOutput Capabilty (amps/ch) - 38 ampsWeight 17 lbs.Size 19" x 8.2" x 2.6"Fuse 4 ohm load - 60 ampFuse 2 ohm load - 80 ampMolex connectionsLeft (+) whiteLeft (-) greenRight (+) yellowRight (-) blueRemote - orangeThese are basically sister amps to the series 7/8 Hifonics Zues , though Hifonics used a variable power supply and no EQLong Live Classic A/B ZEDS !!!!
January 2, 201016 yr This is the SAME amp as a Series VIII HiFonics ZUES power wise. The difference is the Autotek's had the trebble and bass knobs were the HiFonics didn't.Great Amp just don't run it under 4ohm's bridged. It works great at 2ohm stereo.
