Posted April 15, 200719 yr Well Planning for the new truck. And it started out as, Its an expensive truck and its gunna be my DD, so just the stock Navi, a 10 and some door speakers...Then It turned into Well, maybe a couple Head rest monitors and 2 low end 10's in small sealed box....One thing leads to another, and well Im going all out again....Aside from the video equipment and door speakers and chit...I want 2 10in BTLs and a Hifonics to power them...Is there any reason I shouldnt use the 10in BTL for DD?Would I be better of with a BL?And most of you wont care, but ill be finishing up just in time for bike week....which means ill be done in time to turn around and drive back down for SBN
April 15, 200719 yr The shape of the cone causes it to rub on the spider.Fi wont sell you one for DD, and you'd probably be better off with something else.Maybe BL's or a BTL 12"? Perhaps a Q or two.
April 15, 200719 yr Author I knew I heard that somewhere but wasnt sure...thats why I asked..Thank you.I may go with 12's but I doubt it. Room is sorta limited. Maybe ill just go with the BL 10 as Im pretty happy with my BL now..
April 15, 200719 yr I wont make a fully loaded 10, but we have made the standard versions and recently shipped out a 3 magnet 10". The 10s arent the optimal sub out there for daily. VERY low qts which leads to a saddle shaped response curve. Id recommend the BL10 for all but the most high power daily setups. BL10s seem to be very solid. How much space do you have to work with?Thanks,Scott
April 15, 200719 yr Author Im thinking I can probably do around 3 cubes total...two seperate boxes though 1.5 each..maybe a little lowerI was hoping to throw 2500w to each sub
April 15, 200719 yr Wow... 2500W each. Well I might be able to work a wee bit o magic and make something happen with that. What tuning are you looking to do?
April 15, 200719 yr Author Yeah well as close as I can get to that with a Goliath. Thats why i wanted a Fully Loaded BTL...I was planning on 32hz...but thats tottally up in the air.As I said, this started as I wanted the very basics to have a good sounding system. now Without subs and amps im already gunna be about 5k deep into this...
April 16, 200719 yr Author What exzaclty could you do for me lol..i mean i want it to be a DD...soo if thats to much to do just let me know I could def settle for something else..
