Posted April 15, 200718 yr hey guys , i recently ordered 2 15 Q's , am going to run them off of a single SAZ-1500D , with 1500rms to both subs.i want to build the box before the subs get here , and had to ask for advicei noticed on the Fi website that the recommended size for each Q15 is 2-2.6 CF.i can give each 2.5CF .will i get good lows? will i lose anything? not enough power to them?im not planning a LOUD LOUD system .. just loud and clear;)thanks.Eli.
April 15, 200718 yr 5 cuft for the pair yields a .81 Qtc and an F3 around 35 hz. Most peole tend to like a Qtc above .7... actually many like .9 or more... but I feel that it is mostly due to the lack of integration to a weaker front midbass. If you have some ballsier front midbasses, then you can deal with a lower Qtc and an overall smoother integration and response.I prefer lower Qtc alignments, but I always have a strong midbass upfront. It should make for a nice SQ setup...Thanks,Scott
April 15, 200718 yr Author 5 cuft for the pair yields a .81 Qtc and an F3 around 35 hz. Most peole tend to like a Qtc above .7... actually many like .9 or more... but I feel that it is mostly due to the lack of integration to a weaker front midbass. If you have some ballsier front midbasses, then you can deal with a lower Qtc and an overall smoother integration and response.I prefer lower Qtc alignments, but I always have a strong midbass upfront. It should make for a nice SQ setup...Thanks,Scottthanks for the fast replyim pretty sure my front stage would carry the bass forwardso basically i need to build a bigger box? i can squeeze about 3cf per subs in my car, would this get me better results?im looking for good linearity at at the low ends , about 30hz is what im looking for, while still remaining in a sealed box.thank you for the quick answer ScottEli.
April 15, 200718 yr Larger will lower the Qtc of the system and yield a little more "natural" sounding bass. But "natural" is much more of my personal sonic opinion and preference than anything.3 cuft will lower things slightly... but for the extra cuft of enclosure and the gain of .6 dB at 20Hz, I dont think its worth it. Not too mention that by adding up to 1lb of polyfill per cuft of enclosure you can "add" about 17% extra apparent box volume as well. So at that point, your 5 cuft will act pretty close to 6 cuft.In all honesty you wont hear much of a difference between the two alignements. And with a standard vehciles transfer fucntion (cabin gain) you will have a very smooth overall setup with a nice tilt up towards the bottom end.Thanks,Scott
April 16, 200718 yr Author Larger will lower the Qtc of the system and yield a little more "natural" sounding bass. But "natural" is much more of my personal sonic opinion and preference than anything.3 cuft will lower things slightly... but for the extra cuft of enclosure and the gain of .6 dB at 20Hz, I dont think its worth it. Not too mention that by adding up to 1lb of polyfill per cuft of enclosure you can "add" about 17% extra apparent box volume as well. So at that point, your 5 cuft will act pretty close to 6 cuft.In all honesty you wont hear much of a difference between the two alignements. And with a standard vehciles transfer fucntion (cabin gain) you will have a very smooth overall setup with a nice tilt up towards the bottom end.Thanks,ScottThank you very much Scott !realy good tips you gave me therei need to get the subs to get to know them better , and maybe change a few boxes and see what they can do while sealed maybe ABC box will come eventually;) who knowsi drive a Honda CRV 98 , and have about 10CF i can spare if i must but im trying to keep it below the window linei can already see myself building 5 different boxes for the subsmmmm chocolate MDF
August 3, 200718 yr Author been awhile , just thought of updating with some old pics i have from the box build at one of my friends garages.i will let the pix do the talking , just playing around with the subs.my friend thinks about why do i need two 15"sjust purdyteh ghetto terminal inspired by one of the Fi members [thank you!]teh Q standing next to my 10" Morel Elate midbass!and a short short vid to finish.thanks all
