http://www.power-sonic.com/index.php?id=31&gr_id=40
They use the same glass mat technology as Kinetik. I'm thinking about putting three of these in the back of my car. What do you think?
Nominal Voltage........................................................ 12 volts (6 cells in series)
Nominal Capacity
20 hour rate (5.5A to 10.50 volts) ................................................... 110.0 A.H.
10 hour rate (10.3A to 10.50 volts) .................................................. 103.0 A.H.
5 hour rate (17.7A to 10.20 volts) .................................... 88.5 A.H.
1 hour rate (61.8A to 09.00 volts) ............................................... 61.8 A.H.
15 min rate (204A to 09.00 volts) ......................................................... 51.0 A.H.
Approximate Weight................................................................. 70.6 pounds (32.0 kg)
Energy Density (20 hour rate)................ 1.79 Watt-hours/cubic inch (109.2 Watt-hours/l)
Specific Energy (20 hour rate)............... 18.7 Watt-hours/pound (41.25 Watt-hours/kg)
Internal Resistance (Fully Charged Battery)................. 2.9 milliohms (approximately)
Maximum Discharge Current ( <_ 7 Min.)....................... 330 amperes
Maximum Short-Duration Discharge Current ( <_ 10 Sec.)..................... 660 amperes
Terminals ........... Type
Edited by dopey
The powersonic PS-121100 vs. Kinetik 2000
And the PS-121400FR vs. Kinetik 2400
The way I'm reading this it seems to me like the Kinetik can deliver 3x the current for bursts than the PowerSonic can...
See...Kinetik doesn't give a good spec description for that.
At a direct short, BOTH batterys will deliver FARRRRRRRR more current than either rating. Kinetik doesn't specify how they arrive at that "amps" rating. Powersonic does. That is a plus for PowerSonic as far as I'm concerned.
To me this is the equivilent of a "max wattage" figure on amps. If they list a "max wattage" but don't tell you how they got that figure...I try to stay away.
Edited by dopey
I will get mine from a local battery specialty shop. I'm in northwest Arkansas.
Shipping would be pretty expensive, but still MUCH less than a Kinetik in the end.
Edited by dopey
