Posted April 17, 200719 yr I just built a 4th order BP box for a Panasonic 10" woofer, and it sounds terrible. Not "bandpass" bad, just designed wrong. The frequency response is WAY off.Here is what I have:Panasonic 10" t/sVas: 42 LFs: 30.0 HzQts: 0.37I input that into the calculator on carstereo.com and came up with:Volume front = .397 ft^3Volume rear = .533 ft^3Fb (front side) = 58.3 HzFrequency response ~ 35-90 HzAdded sub displacement and port displacement to the front and rear volumes and built the box.Due to the small area, I could only get a 3" port into the enclosure. Maybe that is too small? Calculated a 3" x 12" long port.Anybody tell me what to do different?????Thanks!Brian
April 17, 200719 yr Author Found the problem. Amp I am using is made by Metra and says it has a LP filter. It does not, or if it does it is not very good..Added a 80 Hz LP filter on the input to the amp and the sub came to life.A little port noise, so I am going to try to find a 3.5" port tube tonight (that is the largest I can have in this design).Thanks for the input!Brian
