Posted April 19, 200719 yr i would like to know the dimensions of what 5-10 cubic feet is...im not a math whiz sorry. i would like to know roughly how long and tall it needs to be to meet 5-10 cubic feet.thnx so much guys,mike
April 19, 200719 yr If you can go and measure the approximate width height and depth you have to work with, we can calculate a box from that. If you have more than the required space, let us know which dimensions you would like to shrink down first.Thanks,Scott
April 19, 200719 yr Author If you can go and measure the approximate width height and depth you have to work with, we can calculate a box from that. If you have more than the required space, let us know which dimensions you would like to shrink down first.Thanks,Scotti will have a lot of height and quite a bit of depth but im not sure about length...do you think you could work with that..cause it will most likely be in the back of a blazer xtreme or a 2dr blazer. im diggin the 18'' cause come on nobody has one. around my town..the best we got is a 10'' W7 and some dumb kid with 2 12'' l7's on a memphis belle 1000.
