Posted April 20, 200719 yr i was told by re that the mt really dont need that much power to bump why do the btl need so much power if their just about the same woofer
April 20, 200719 yr i was told by re that the mt really dont need that much power to bump why do the btl need so much power if their just about the same wooferRead what I said on CA.COM to your exact same question...nG
April 20, 200719 yr Author i was told by re that the mt really dont need that much power to bump why do the btl need so much power if their just about the same wooferRead what I said on CA.COM to your exact same question...nGi post the sam question on different forums to get more opinions
April 21, 200719 yr Admin What amp are you using, and is this for competiton or daily or both?If it is for daily and you dont want to run a ton of power but want to stay in that range, look at the Fi BL.
April 21, 200719 yr Author What amp are you using, and is this for competiton or daily or both?If it is for daily and you dont want to run a ton of power but want to stay in that range, look at the Fi BL.well its going to be mainly for daily but for neighborhood comps every now and then
April 21, 200719 yr i was told by re that the mt really dont need that much power to bump why do the btl need so much power if their just about the same wooferRead what I said on CA.COM to your exact same question...nGi post the sam question on different forums to get more opinionsI know, I'm just saying I answered you on the other forum too!nG
