Posted May 4, 200718 yr I know there is probably no definitive answer, but I wanted to know where to start. I decided on a sealed box for new Mag 15 on the way to me. I figured 2.6 cubes and 2.45 after displacement. I want to know how many pounds to start with. I am looking for about the same output as my ported 12, with a flatter response. I know the site recommends 2.3. Is my box too big? Os there a way to get a little more output from a sealed box without losing a whole lot of SQ. This is my first sealed that I have had in this car. It will be getting around 1100 watts. I listen to about everything.
May 4, 200718 yr You might not like any or you might like a lot. Give a listen and just use what sounds best to you.
May 7, 200718 yr Try it without any fill at first and if you want to try filling it, use 2 pounds of polyfill when you fill the enclosure.
