Posted May 9, 200718 yr hey guys, im a noobie to this forum. a lot of you probably recognize my sign name/this build. here are all the pics as of now. well i have got all the wood cut other than the top and the inner port wall. other than that everything is going well. i am waiting for my 1" baffle for the sub to dry..then i can work on the mounting system for the sub(you'll see). here are some picsme screwing sub to 1" baffle.the perdy sub in the baffle. the gap was fixed btwfloor piece done. the toughest part as of yeta view from inside the carmy bud holding it in placethe half inch bolts to mount the sub into the boxbolts through the 1.75" thick baffleass shotside profileright frotn pieceattached to sub baffleall together now
May 9, 200718 yr Author oh, i just took this...you guys should like this one...btw, i bought my amp from SS Steve, from British Columbia..which is where i got the sticker
May 9, 200718 yr Author thanks guys. i will continue working on it today in 3 hours after school here is a 3D rendering of what it will look like when complete. its 6.4 after port/sub displacement and is tuned to 35 hz with 93^2" of port....however i may drop the tuning a little lower. we'll see...
May 10, 200718 yr Author dry fit out of the caryou cam see that its about an inch off..but its no biggy(top left) floor donecovered to reduce rattlesso close to the top...yea i had to use the 1/2" to make it workall mocked upglued and screwedand caulked
May 31, 200718 yr Admin wow, your really pooring your time into this, tons of cuts, looks soooo easy from your pics, lol
