Posted May 10, 200718 yr I see alot of post where guys are running there amps at .7 ohms, how is this possible. I have run amps at 1 ohm or even .5, but how do you get .7??
May 10, 200718 yr Author I understand that part, so what coil config will run an amp at .7? I know 2 D2 subs will net you a .5 ohm impeadence, but what VC config gets .7? What? quad coils or something?
May 10, 200718 yr three dual 4 ohms, wired in parallel/parallel would be close (0.67)... and higher with impedance rise.
