Posted May 20, 200718 yr 15" audioque hd3 dual 1.5 coilsis there anyway i could have this reconed to a 18" btl? Edited May 20, 200718 yr by JoshHd6
May 20, 200718 yr No...a BTL is a BTL..a hd3 reconed with different soft parts would be just that, a hd3 with our coil, spiders, and cone.
May 20, 200718 yr Author No...a BTL is a BTL..a hd3 reconed with different soft parts would be just that, a hd3 with our coil, spiders, and cone.thats what i meant lol..so it can happen?
May 20, 200718 yr Honestly man there's really no point in doing it unless you killed your hd3..Recones from them are decently cheap, and you wouldn't have a 'frankenwoofer'
May 20, 200718 yr Author Honestly man there's really no point in doing it unless you killed your hd3..Recones from them are decently cheap, and you wouldn't have a 'frankenwoofer'i would if they built a 18" sub..lol
May 20, 200718 yr Author Probably better to sell the sub you have and buy one that is designed to be a 18.ok..thats what ill do then..
May 20, 200718 yr You should try contacting Audioque first, I know the website lists some info on an HD3 18 - but its also not available to order on the website. Im sure they'll know best about if/when it will be available for purchase or recone.
