Posted May 24, 200718 yr Hey guys. I am looking at this Usa-100Hc and I need some specs on it. If I was to get it I would be putting around 14.4 volts to it..I see at 1 Ohm it is rated at 800 watts..Do you guys have any info on it? I have done searches, came up with minimal material..Wanted to talk to the Us amp masters...Oh yea it is the Old style Usa-100Hc if that helps..The longer model...Thanks guys..Also would it be a better amp than my current Xt4000d??? I love the old school amps..
June 8, 200718 yr Hey guys. I am looking at this Usa-100Hc and I need some specs on it. If I was to get it I would be putting around 14.4 volts to it..I see at 1 Ohm it is rated at 800 watts..Do you guys have any info on it? I have done searches, came up with minimal material..Wanted to talk to the Us amp masters...Oh yea it is the Old style Usa-100Hc if that helps..The longer model...Thanks guys..Also would it be a better amp than my current Xt4000d??? I love the old school amps..Call Greg at US amps toll free at 1 877 267 9360 for not all the USA 100hc were the same.
July 13, 200718 yr IIRC, that is 50x2 at 4 ohms. 1/2 ohm stable and it is 23" long. If you are brave and have the electrical system to support it, it will run at 1/4 ohm. I think they put out a tad over 1KW at 14V into 1 ohm mono.Just curious, what color is it? I had a USA-400 (same size) in gloss purple way back when. The florida splash finish was awesome. Ahhhh, the memories. Edited July 13, 200718 yr by bigjae1976
July 13, 200718 yr Specs per 92 catalog/ USA-100HC----------------------------------------4ohm-50x22ohm-100x21ohm-200x2.5ohm-400x2Bridged@1ohm=8002x8awg powerwire inputTHD <.009%IMD <.03Signal to noise ratio 115dbFrequency response 5hz-50khzSlew rate 150VusInput sensitivity 250mv/10VVari-loud/NOPreamp outputs/NOActive crossover/NOFUSE/100ADIMENSIONS 7.7x2.3x20 inchesDamping factor 1000
