Posted June 1, 200719 yr i need to finish out the boxx and wall off the open side where the batterys go
June 1, 200719 yr Author no steel threading?im lost why would ya steel my thread the port in the 1st pic sitting on the boxx is my "Street beat" dropp in 38hz without it the boxx is 54Hz Edited June 1, 200719 yr by Lord Baccus
June 1, 200719 yr Admin Keep the pictures coming, I wish I could mess with walls. But I am starting over back in Street A.
June 1, 200719 yr Admin no steel threading?im lost why would ya steel my thread the port in the 1st pic sitting on the boxx is my "Street beat" dropp in 38hz without it the boxx is 54HzHe is talking about the long steel threads that many people are using as barceing because they take up less volume then mdf and are stronger and adjustable.
June 1, 200719 yr Author Ohhhhhhhhhhhhhhhh I am going to get some Allthread ASAP ...box had to go in as it was for the competition as i ran out of time
June 1, 200719 yr Author i gotta few things still too do in the boxx :Brace w/ allthtreadadd 45degree anglefigure where i want the port / drivers or passengers side...ect ect ect fill in wall where batterys go & over box cover wall with black carpet
June 1, 200719 yr Author if the mic is higher in the drivers side kick should i put the port on the drivers side ? or passanger side to give it time to load better ??
June 1, 200719 yr if the mic is higher in the drivers side kick should i put the port on the drivers side ? or passanger side to give it time to load better ?? meter on driver=port on passengermeter on passenger side=port driver side
June 1, 200719 yr Author i thought as much i have to flipp the boxx ASAP.have competition on the 10th need to get some bucket seats...
June 2, 200719 yr if the mic is higher in the drivers side kick should i put the port on the drivers side ? or passanger side to give it time to load better ?? meter on driver=port on passengermeter on passenger side=port driver side=Put the speakers on the same side as the mic.
June 2, 200719 yr Author if the mic is higher in the drivers side kick should i put the port on the drivers side ? or passanger side to give it time to load better ?? meter on driver=port on passengermeter on passenger side=port driver side=Put the speakers on the same side as the mic.that means i have too flip the boxx
June 2, 200719 yr if the mic is higher in the drivers side kick should i put the port on the drivers side ? or passanger side to give it time to load better ?? meter on driver=port on passengermeter on passenger side=port driver side=Put the speakers on the same side as the mic.that means i have too flip the boxx Or just turn the car around.
June 20, 200719 yr You should build a new box as wide as you can, and move the subs as far over to the passenger side as you can, so you can have more port area.
June 21, 200719 yr Author I originally built that box How so ???Are you a Friend of Doug B. ??? do i know you ?
June 21, 200719 yr Me and Doug are pretty good friends. I drive a blue 04 silverado. Been to a few TBP shows. Mostly watching, sometimes I enter my truck. More of a USACi guy.
June 21, 200719 yr Author Cool ! i have Modded the boxx by adding another faceplate, fiberglass resin, 1/2 round trimm in the seems, and will be adding a few secret angles to help the port to load better, built a dropp in port for Street Beat. just got dougs other boxx with the Twin 6" Flared ports
June 21, 200719 yr Yeah, we basically threw that box together. When we found out it wouldn't fit the way we wanted to AND that DD didn't ship the recones that he ordered, we stopped trying to make it bullet proof. Basically just left a shell with a single window brace. Im going to try and make it over to DFW again in July that way me and doug can work on a box for his new project.
