Posted June 2, 200719 yr I'm too lazy to A. Look down this page a bit to see the other 8 questions asking the EXACT SAME THING.&B. Use the search function.&C. Go read the stickys at the top of the page that list recommended enclosures for all of Fi's subs....so I figured I'd pollute the board some more with my "problem" that really isn't a problem, and doesn't need anymore discussion.Thank you.
June 5, 200719 yr Author I also haven't measured to find out if my sub box will actually fit in my car. Or if I'll have enough airspace once it's built.How does this sound...32 x 12"Q's Powered off 3 x 100.2'sI have about 3 cubic feet to work with...will someone design me a box that SLAMS!!!
July 9, 200719 yr I also haven't measured to find out if my sub box will actually fit in my car. Or if I'll have enough airspace once it's built.How does this sound...32 x 12"Q's Powered off 3 x 100.2'sI have about 3 cubic feet to work with...will someone design me a box that SLAMS!!!Fishercustoms.com , ask for Chris he'll set u up
July 9, 200719 yr Fishercustoms.com , ask for Chris he'll set u upuh Edited July 9, 200719 yr by static
